[社会广角] 万能句来啦!考研英语二大作文万能句终于整理全了!
发表于 2021-7-26 10:32:07 | 显示全部楼层 |阅读模式
考研冲刺焦虑期,脑袋好像也不怎么好用了的节奏,不少小伙伴着急的连模板范文都背不下来啦......于是乎,为了减少大家大脑的压力,征小辰又帮大家整理了一些考研英语二的万能句,开头中间结尾都有了,要不你们选几个还看的下去的背背?
开头万能句型
(1)开篇万能句型(概述图内容)
①According to the table/pie chart/line graph/bar graph,we can see/conclude that…根据该表/图, 我们可知……
②The table/graph reveals(shows/indicates/illustrates/represents/points out)that… 该 表 / 图 表 明……
③As we can see from the table… As can be seen from the line/bar graph… As is shown(illustrated/indicated)in the pie chart… 如表/图所示,……
(2)描述增减变化常用的句型
①Compared with…is still increased by…
②The number of…grew/rose from…to…
③An increase is shown in…;then came a sharp increase of…
④In…the number remains the same/drops to…
⑤There was a very slight(small/slow/gradual)rise/increase in 1990
(3)表示数据变化的单词或者词组
  • rapid/rapidly 迅速地,飞快地,险峻地
  • dramatic/dramatically 戏剧性地,生动地
  • significant/significantly 有意义地,重大地,重要地
  • sharp/sharply 锐利地,明显地,急剧地
  • steep/steeply 急剧升降地
  • steady/steadily 稳固地,坚定不移地
  • gradual/gradually 渐进地,逐渐地
  • slow/slowly 缓慢地,不活跃地
  • slight/slightly 轻微地、略微地
  • stable/stably 稳定地
中间万能句型
1.The most obvious reason for this phenomenon is that_____.Consequently,______
2.No matter you like it or not,AAA has become more and more popular and there are many reason for it.
3.It’s an urgent task for us to change this unfavorable situation:______
4.The picture can reminds you of some strange,yet familiar phenomena existing in our society.
5.A great number of solutions are being offered.Some people suggest that_____.Others argue that_____.
6.Confronted with AAA,we should take a serious of effective measures to cope with the situation.
7.However,_____may cause some problems.First,it is______.Second,_____.Finally,_____.So,it is clear that______has its advantages and disadvantages.
8.Although_____has a great advantage of_____,it can’t compete with_____in_____.
9.____may be preferable to_____,but_____suffers from the disadvantages that_____.
10.The advantages of______are much greater that those of_____.For instance,______.
11._____may be preferable to_____,but it also suffers from the disadvantages that______.
12.But I don’t think it is a very good way to solve_____.For instance,______.Worst of all,____.
13.There are many ways to______.First,_______.Second,______.Third,_______.
14.On the contrary,there are some people in favor of______.They believe_______.Moreover,they think_______.
15.There are several measures for us to adopt.First,we can______,there are a number of advantages of_____.Another solution is to______
结尾万能句型
1.The most effective means to solve this problem is that______.In that case,______.
2.Everything has its own two sides,no exception with AAA.For>
3.My experience tells me that to______needs a thorough and persevering process,and in this process you had better abide by the principles mentioned above.
4.On the whole,it is high time that we recognized the significance of______.
5.As a result,we should take some effective methods to______.
6.Judging by the figures,we can draw a conclusion that______.
7.In a word,the whole society should pay close attention to the problem of______.Only in this way can______in the future.
8.In my opinion,we should place much emphasis>
9.But______and______have their own advantages.For example,______,while______.Comparing those two,however,I prefer to______.
10.In my opinion,_______is just as common as______.If______,it may be very useful.Whatever______,the key point lies in______.
11.Are their opinions correct?To my mind,the first idea seems______.As for the second idea,______.
12.As a popular saying goes,______.In my opinion what really counts is not______,but______.I believer that as long as______,we will______.So I am for the opinion that______.
13.In my opinion,both sides are partly right.When we______,we should take into consideration all aspects of the problems,and then make the right decision.
14.Personally,I believer that_______.Consequently,I’m confident that a bright future is awaiting us because______.
15.In my opinion,all of the people should be brave enough to show our disapproval and criticism when confronted with______.
小编还有话说
图标作文的篇章结构大致可以分为三大段:第一段往往分析图表中的数据变化反映什么问题或趋势,概述图表所揭示的信息。第二段分析造成这一问题或趋势的原因。第三段则展望未来的情况或提出解决问题的办法或建议。
上面讲述的15个开头万能句,10个中间万能句和15个结尾万能句,希望大家选择自己擅长的自由搭配,灵活使用,大致按照三大段的整体框架来写,在一定程度上还能避免成文的死板,感兴趣的可以试试看哦!
